Nightster Blinker (Leds)
  • ratafcuk
    ratafcuk
    Hi,
    is there any nightster owner that could help me?
    I bought a pair of nightster blinker to put on my Sporty '07, they have four wires and I could make them work as run/brake but not as blinkers, even with a load equalizer but nothing.
    Can anyone tell me how is connected on a nightster?? thx
    Raf
  • 1elcys
    1elcys
    You may wanna ask this question in the workshop section lots of knowledgable people there.
  • ratafcuk
    ratafcuk
    Ok thanks!! and do you know how to move this post to the right place?
  • ratafcuk
    ratafcuk
    Hi Captain,
    Thanks for your reply, I've tried everything but no result. I have a second hand one and doesn't blink, but I bought a new one and exactly the same. I'm desperate.....!!
    Could you please send me the wiring diagram that appear on your Service manual, so I could see if I'm missing anything.
    Thanks again
    Ratafcuk
  • sportytrace
    sportytrace
    Which wiring harness have you got? Is it 68955-08? It sounds like you may have the US harness (68278-07).... the US nightsters do not have the same led setup. You want the harness that doesn't have the converter module.
  • ratafcuk
    ratafcuk
    Hi all,
    Thx for your replies.
    Sportytrace, I actually have a sportster 07 and I don't know if the problem is the harness, I don't think so, cause I built one to be to able to connect both blinkers, seems like a different blinker module. In Europe the nightster is exactly the same as in Australia but I don't know if it has a different blinker module as a Sportster. A wiring diagram would help me.
    Bucket, I bought a blinker through ebay and the other one at www.lshd1.com and cost me US$212 plus shipping. The reference number is 69360-08.
    Just a second, I just tried to hook up as Captain said, here at home with a power supply, and yess it works. Now I have to try it on the bike.
    Seems like it is the harness.
    Thanks so much to all
    Rataf
  • sportytrace
    sportytrace
    The 07 harness on the sportsters has the converter module... the international nightsters do not.... with harness 68955-08 it should be plug and play :)
    Looking forward to hearing how it went on the bike.... fingers crossed for you :)
