Online:
Hilly
K&N filter for dyna stage I air cleaner ?
Bobby Boy
There is an K&N RK series unit wich comes with a new back plate. Fits your normal cover too!
If I come across the model I will post up.
Rob
sophtayl
try H29406-08..
M
MickDB
I fitted an Arleness Big Sucker to mine and put the stock chrome cover back on..... but it seems that the cover is much higher than it used to be..... i have only about a 10mm gap between the fuel tank and the top of the air filter cover.... i would be interested to know if yours is the same after you fit the stage one filter...
