do l need digi, technician??
  • kickinon
    kickinon
    Wel l ive taken all the parts off for examination while lm waiting for my electrical diagnostic manual to arrive from the states, THE
    ecm, ckp, map, iat,et, iac, but not the tp,or vss just looking for something out of the ordanary, you know, maybe get lucky find a loose conection or a rubbed out wire,,,,no such luck!
    every thing looks o.k.,
    so ive been brushing up on wot l need to check out on the EFI system , when the book lobs, thought id ask weather l need to
    down load anything ? to check the H.D ecm?? or other things ?? l here there s a digital tecnition for setting idleing & wotnot, but is that for  dealers? or the public?
  • kickinon
    kickinon
    hey thanks scotty, ive got the multi meter, will check when the manual arrives,
