Online: baldy1450
2004 Sportster 883 & 1200 Review
  • kingchops
    kingchops
    18 years ago
    Found this article, it's a good reference for what has changed in the '04 and up Sporty's:
    RoadCarver Motorcycle Reviews
    Harley Davidson 2004 Sportster 883 & 1200 Review
    Harley says that they’ve “really changed the Sportster inner workings”
    – not just the cosmetics.
    Is it just another marketing scheme? In a word, “no.” Before the launch, HD wanted to create a Sportster that you could buy to keep rather than using it as a stepping stone to the bigger Harleys. Our weekend aboard the XL 883 & XL 1200C certainly proved that point.
    Firstly, I was never a big fan of the Sportster. Many HD folks looked at the baby Harley as something for the not-so-strong, or well off. Even “a good bike to start off – but ditch it as soon as you can afford a…” The Sportster, at times has also been called a chick’s bike because of its smaller base and relative ease of handling – which makes you wonder why only the girls are supposed to get the easy-to-ride, nice handling bikes.
    Going on all the propaganda about the Sportster not being “all-that”, we were not expecting to be overly impressed.
    Most bikes look better in the flesh, but I’d say that especially goes for Harleys. If all that chrome and shiny gear doesn’t do it for you, you might as well stay at home.
    The good folks down at Blacktown Harley wheeled the Sportster outside and started them up.
    This pair hadn’t been hit with the screaming eagle just as yet so the sound coming out of the pipes was still a very legal-Harley burble. If you give these bikes the once-over, you can tell straight up that the team has been working overtime to get every last fitting looking great. No real rough edges at all and the build quality is excellent.
    Aboard the 883, the first thing we always notice is the seating position. Not quite cruiser-like or sporty (in a modern sense). It does feel pretty strange to begin with, but after a while you really do get used to it and makes a great set-up for swinging the sporty into the corners. The 1200c in contrast has the “easy rider” layout that looks very cool and is great for cruising the highway. The 1200c also has reasonably good ground clearance and sits firmly through the bends, but the seating position makes the tighter stuff a bit more of a challenge than the 883. It’s really up to you to decide what you’ll be doing more of. Having said that, we were all really impressed with the way both Sportsters held their line in the corners - A real surprise.
    A major update we were hanging for was the engine of the 883. The last time we tried one, we weren’t too stoked. It seemed to be plagued with vibrations and harsh engine noise – not to mention uninspiring performance.
    We are real happy to say that the 2004 XL883 is a massive difference and justifies the marketing targeted at the Sportster line-up. The rubber mounted engine has really smoothed thing out as well as putting out some great usable power. Inevitably there will always be people looking to extract more power from the beast, but even as is, the 883 is a hoot to ride. Power aside, the 883 was smooth and torquey.
    With the radical changes with the other components of the bike, the previous evolution engine needed a bit of work to get it up to speed. Although the 45 degree v-twin set up and bore and stroke remain unchanged the cylinder heads on the 883 and 1200 have both been redesigned. Lighter and stronger internal components combined with a new oil cooling system have significantly reduced engine heat. The 1200 has received the most changes with performance cams, high flow heads and an increased redline from 5500rpm to 6000rpm. All this equates to around a 15% increase from the 03 model giving it 70 hp and 79ft. lbs. of torque. The 883 has not benefited in the same way but still makes a healthy 53 hp and 51ft. lbs. torque a moderate increase from the 03 model.
    The way the Sportsters make the power has also had its fair share of treatment too; a new timing system, air cleaner, exhaust and the conversion of parts to quality engineered components have made the Sportster better. The engines are a lot smoother and the power comes on earlier and lasts a bit longer.
    Power on the 1200c was probably never really an issue and certainly not on the 2004. This Sporty custom pulls like a freight-train with bucket-loads of torque in any gear. Speaking of gear it feels like it has seven and a half. A number of times we reached what we though was top-cruising gear, only to find we had two more to go. 5th gear doesn’t really get useful till’ around 120. This baby is built for cruising big open roads (that could use a higher limit). We actually needed to hang on when giving the throttle a good twist – you’ll be sure to lose a passenger at this stage (more on that later)
    Being a bigger twin, the vibes came through more on the 1200c, but never really annoying apart from the buzzing mirrors. Who wants a HD that doesn’t buzz just a little bit? It wouldn’t be right and it wouldn’t be from Milwaukee. If you catch the bigger twin in low revs, it will chug a bit, but that is really the odd occasion.
    Firmness is something that hits you as soon as you throw a leg over on either of these bikes. The seat feels like rock when you first plant your backside, but magically seems to soften (or numb). We only got sore after riding for a good 6 hours +, which will leave your butt aching from most bikes anyway.
    The seats are well contoured for a stable sporty rid and have a ridge at the back to stop you from sliding off on fast take-offs. We found the ridge useful especially on the 1200c because of the power and seating position.
    The 883 was a single seater and the 1200c may as well have been. If you can fool someone into riding with you, they will be sure not to come a second time. The seat does look cool, but that’s about it. Our test passenger had this to say (we dedicated a whole section to the seat, or lack of it:
    XL 1200 C – A passengers’ perspective
    Traveling the roads on a Harley Davidson is the dream of most motorcycle riders at one point in their riding carrier. The roar of the engine, its brute force and its reputation seem to scream something which only those who want to hear can receive.
    For those not fortunate enough to have their own there is the possibility of ‘tagging’ along for the ride, that is become a Pillion. To be a passenger on a Harley Davidson is an honour in itself yet one might consider a few things before taking up the ranks of Pillion on an XL 1200 C.
    Firstly the 1200 C is a powerful motorbike, no doubt about that, if the driver decides to ‘give it some’ you better have a REALLY good hold or else you might become the next temporary speed bump for the vehicle behind you.
    Second: The passenger seat on this particular model is very short. You better have a small backside if don’t want to sit on the rear mud guard. The seat also seems to be angled the wrong way and can force the thrust of a quick burst to throw you even further back. Because of the seats length it seems like the holding strap is almost behind you and does not provide the stability needed in acceleration. It does provide a little slack which would be great if it was a little more forward.
    Holding the rider is fine and is probably the best and most comfortable bet although something about one man hugging another on a Harley from behind with both arms got a few glances along the way.
    One positive consideration is the foot pegs being a little forward which helped when slowing and stopping the bike. Instead of sliding forward, like you were on melted butter, you can brace the deceleration gently and not force yourself onto the rider and avoid clunking of helmets in ritual fashion.
    The shocks could have been a little softer during this test and can be adjusted for personal preference.
    In summary, the XL 1200 C is a great individual bike which can facilitate a pillion. Due to the seats length and angle it becomes very difficult to ‘cling’ on to the rider. This is a positive if the passenger likes an adrenaline rush every time the bike accelerates and is almost thrown from the seat.
    The holding strap provided is easy to grip but makes it feel like you are trying to wipe something and only seems to come into effect when you are almost off the seat.
    This bike was made with a passenger in mind but I would not recommend trips with a lot of stop-and-go.
    Recommendations would depend on the bikes purpose but if a passenger came into the discussion a longer seat, possibly with a small back rest would be advised.
    At the end of the day it gives you a damn fine excuse to get rid of pesky would-be-passengers….its a damn Sportster! And – In all fairness, most bikes when new are sold to look good, not for practicality. There is also an arsenal of aftermarket seats to accommodate any whining.
    The great handling of the two Sportsters owes a lot to the suspension and Harley have made changes in this area too. The rear tyre has been widened from 130mm to 150mm and a new 25% stiffer chassis has been designed around it. The frame and swing arm have been strengthened as well and now the 1200 also sits lower.
    The demo 883 we rode had great shocks giving us a smooth ride on all but car-sized potholes. Strangely enough the 1200c was a lot stiffer only because of the setting on the rear shocks. On these setting the 1200c was hard as nails, giving heaps of stability but knocking the wind out of you on harsh bumps. We didn’t have the tool to change the suspension settings out on the road, but we figured it would be as good as gold with a few clicks. The stiff setting would be just right with an extra body on board.
    A new braking system features single disc front and rear for both 883 and 1200.
    The lever effort has been reduced from previous models but I still found that the feel of the brakes was a little dull with no initial bite. This probably is not such a bad thing for inexperienced riders as you won’t get in trouble by grabbing too much brake. Braking was satisfactory and is an improvement from the old models but could be improved quite a bit.
    The gearbox on both rides was very good. As you would expect, they need a bit more shoving than a Jap sports bike and give a definite “clunk” as you shift. None of this is bad really as I personally wouldn’t want my Harley any smoother than this because I’d forget what I’m riding. Shifting was fine, no complaints there. 1st gear on most HD’s is quite tall and can make slow-speed maneuvering tricky business – but then these ARE Harleys, not Pizza deliver scooters.
    The instruments on the Sportsters a kept to a real minimum as you would expect – No clever gadgets to keep you from looking at the road, which has got to be a good thing. What we did like was the quality and user friendliness of the buttons and switches. The operation of the switches was soft and smooth with no harsh clicking or hard to push buttons plus the indicators had auto cancel function which is always a plus. The only thing that we could find a fault from was a missing trip meter and a tacho.
    We didn’t get a chance to test out the lights at night, but during the day the headlights on the Sportsters looked a bit dim compared to other cruisers we saw passing by.
    All up, we were thoroughly impressed with the two Sportsters and we thought they did their job well. They looked great. Sounded great and gave decent sports-like performance. You might not be beating Troy Bayliss around the track on one, but we did surprise a few of the weekend café racers!
    Photos & Review by: George & David @ RoadCarver
    Original URL; http://www.roadcarver.com/reviews/04_hd883_1200.htm
    RoadCarver
    + Click to enlarge
    + Click to enlarge
  • ANDYK
    ANDYK
    18 years ago
    All Good
  • bretho
    bretho
    18 years ago
    very good read, not to sure about the std horse power noted though, cheers bretho
  • con7502003
    con7502003
    has any one on here got a1200 2004 c just wondering about k&n air filter if you have to rejet,.
  • sportygirl2004
    sportygirl2004
    I found your review very interesting & informative due to being an owner of a 2004 883 which I wouldn't give up for the world as it gives me everything I need and more. I will admit I did set it up from a solo to accommodate my 15 yr old daughter, but alas she only got on it the once :D and refuses to pillion on it again as she finds it too uncomfortable not only on her bum but also her foot placement, poor diddums :( :P :D
  • GK74
    GK74
    thanks for this review it is great info
  • MAGIAN
    MAGIAN
    was reading this article and do agree with most of it, I own an 04 and have had it for 5 yrs, i keep saying i will trade up but havent yet, and no its not my 1st sporty, i would like to add to your article that if you need to repair them thats where it changes everything.  the 04 has many engine mods one of which is the trans which you can no longer remove, you must strip the whole engine to find out wots wrong with it and that is a huge cost....... you cannot change alot of things on an 04 as you can with previous models, you are even limeted with cams that you can use unless you want to spend spend spend, the articles was good but no one ever tells you how much things are to repair. broke tooth on fourth gear $3500
