Online: B0nes, speedzter
07 model bikes
  • kingchops
    kingchops
    18 years ago
    I've only had mine for a few months but I've had no problems to speak of. The amount of engine noise threw me initially but from what I've read this is normal for a Harley. I've read that synthetic oils cut down on the engine noise as compared to the stock Harley oil, so I'll give that a go when I get it serviced I.
  • GREG
    GREG
    18 years ago
    1st and 5th Gear are straight cut, the rest being helical. Straight cut will generate more noise. (most car performance gearboxs use straight cutgears).
    My softail has had no problems. Its reliable, starts first push of the button, pulls hard, gets a heap of admiring looks --- what more could you want.
    I guess with any change of model people will compare it to the last and find things that are different, but not necessarly wrong, with it.
  • nobody
    nobody
    18 years ago
    I think all the 6 speeds have the whine in 5th gear,as mentioned it is due to the straight cut gears.I know that they do run way too hot and that is because they run way too lean,didn't take very long for my header pipes to discolour,but we seem to be spared the problem of the rattle that they had in the U.S. touring models,don't know if it is because we have a different amount of teeth on our sprockets and hence our gearing is different or not.Apart from that I haven't heard of anything else inherent to the 07 models.Harley just have a few problems with fuel injected bikes in general
    nobody
  • Big Joe
    Big Joe
    18 years ago
    Ive had my 07 since January and was initially surprised at how noisy the primary was. the knock that the starter makes just as it fires up had me concerned but the dealer assured me it was normal. none of my other 3 harleys had done this before and being my first twincam i believed him when he told me it was the new starter configuration. Well weve just got back from the goldcoast and its in gettin repaired because two teeth have sheared off the ring gear and chewed out the rotor and the stator. NICE. Oh and make sure that the unsheathed o2 sensor wires that sit in the exposed plastic cable tray dont work there way out and short with the positive terminal of the battery. if this happens it does wonders to the ECM. After it happened to mine ive found a couple of other 07s that started wearing through the wires. Other than these couple of tiny set backs we have had great performance results from the 96ers. Wonder what next week will bring?
  • nobody
    nobody
    18 years ago
    Hey Joe
    and welcome to the forum,glad to hear that someone here has some feeedback about the 07 bikes,what I am wondering is what models are these problems affecting or is it just a generic 07 problem?
    nobody
  • Big Joe
    Big Joe
    18 years ago
    Hi nobody. im not aware of any probs with any other models than the softtails.
  • Big Joe
    Big Joe
    18 years ago
    Well all parts arrived today but dealer still shruggin their shoulders as to why it happened. Should have it back tomorrow.
    stix the cert units are a way to go. i got rid of the dunflop and went back to what ive used before. a venom. What a difference.
  • rooshooter
    rooshooter
    18 years ago
    my 07 electraglide has just clicked over 13000 ks fifth gear has become way too noisy [whine + clatter] oil seeping around the casings and having a lot of oil misting through the breathers into aircleaner then out all over the damn place
    just the ord mods to bike inc vance+hines mufflers, powercommander and k/n air kit
  • stbobrhino
    stbobrhino
    18 years ago
    Hi guys, new on deck here...... I've had my 07StBob since Dec and have put 17000+ k's on the clock so far without any real dramas. Early on I was worried about the engine pinging too much, but that was sorted with the HD torque curve recalibration. On the subject of tyres I got 10000 out of the Dunny rear and am not far off replacing the front. I didn't mind the Dunny on the rear and I've scrapped both sides a fair bit. running me880 metz' now and it's good, just waiting to see how much I get out of it.
  • nobody
    nobody
    18 years ago
    Hi from Sydney and welcome to the forum stbobfhino
    Glad to see that your ride is still going strong
    Yeah I can scrape mine without any dramas on the Dunlops,but after running Avons I find the Dunlops not very confidence inspiring.
    nobody
  • BACAMICK
    BACAMICK
    18 years ago
    07 bob , never had the noise issue or heat issue ,as a 96 it did seem to lug in 6th below 80 od ks
    the missus 07 sporty is fine , both have/had st1 upgrades
    pc3 ss pipes ac
  • rooshooter
    rooshooter
    18 years ago
    just an update on my 07 glide, dealer has agreed that the tranny is way too noisy  and has pulled it apart
    rang to tell me they could see nothing wrong but are going to replace all bearings etc anyway
    this was 3 weeks ago i wonder how much longer i have to wait for my bike?
    why replace bearings if they dont need em?
  • Robbo
    Robbo
    18 years ago
    I'm with Greg,
    alittle whine in 5th gear but nothing to complain about, I did alot of reseach before buying my bike to know what I was getting and an article from AMA mention a slight knock when the starter kicks over and a whine in 5th to do with the gear cut, when I change the oil in the tranny I'm going to look at Redline Shockproof to see if this takes away the whine, but like I said before its hardly noticeable.
  • JC&S34
    JC&S34
    18 years ago
    If I stopped every time I thought I heard a noise I'd never ride the bloody thing. Despite progress in a lot of areas it's still an air cooled engine. Change your oil every 4000 Ks, warm it up before you ride it and dont rev the guts out of it and it will last for years and so will the noises.
  • 07FXDC
    07FXDC
    18 years ago
    You mean you can hear noises from your bike over your pipes?!!! I must be deaf! j/k
    Seriously, no problems with mine in the 6 months I've had it.
    18 years ago
    I think the gearing noise is with Softail and not Dyna range.... but may be wrong. I have had no issues to date (touch wood)...
  • nobody
    nobody
    18 years ago
    The whine in 5th gear is right across the range,because in the 6 speed box,5th gear is a straight cut gear,and one of the trade offs when you run a straight cut gear set is NOISE.
    nobody
  • 07deluxxxe
    07deluxxxe
    18 years ago
    after 750kms ive noticed a harsh nosie at the starter engaging ?? and she clunks into most gears , whilst riding or standing still , feel the clutch might need adjusting at first service.
    other than that , alot better than i was expecting out of a aircooled v-twin.
    cheers greeny
