Online: baldy1450
Bike stand
  • luckymick
    luckymick
    Can anyone recommend a bike stand or lifter that is suitable to use to make it easier to give the ride a tub or change the oil out in the driveway?  Are they different for different bikes? Mine's a 07 Fatboy
  • Mainey88
    Mainey88
    Repco stores sell bike lifters for under 200 bucks luckymick.
  • luckymick
    luckymick
    Thanks, I'll have a look there.
    if you want a lifter
    Have a read of this post...HERE.... bought is from I bought the lift from Hare and Forbes for $489....
    if you are looking at buying off ebay then be aware of weight capacity and length... especially length as some wont be long enough...
    and here is a fat boy on the same type of lift (borrowed from another post)
  • luckymick
    luckymick
    Thanks Unc, that looks like a top bit of gear for the workshop. Sure would make it easier on the old back doing a service.
