IB Bike Lifts
  • Strop
    Strop
       www.ibbikelifts.com
    I.B. Bike Lifts is meant for all motorcycles. The bike lift is based on a semi-modular design and the modules are continually being updated to cover different motorcycle manufacturers makes and models.
    "All models now with tie down points as standard"
    The IB Bike Lift has been designed to provide ease for repairs, maintenance and cleaning, of your Motor Bike.
    The Working Load Limits are:
    Heavy Duty Lift: 450kg. W.L.L.
    The Bike Lift will lift bikes from as low as 9.5cm's with smooth operation and easy to use controls.
    Just simply roll under the bike and positioned to line up with the frame and commence jacking. When the jack reaches it's limit, a safety catch folds down to the lock position.
    On most bikes, the bike can be placed on the side stand, jacked up and lowered back onto the stand with ease.
