First Service
  • allyoop
    allyoop
    Hi
    I'm about to do my first service on my 04 1200 Sport
    K&N air filter
    K&N oil filter
    Motul Twin Syn 20/50 oil
    Can you tell me, is it ok to use non-Harley spark plugs (NGK DCPR7E)?
    Also, any traps I should look out for?
    cheers, al
    I
  • allyoop
    allyoop
    Found this info
    It doesn't actually state for the Sport model. But I'll give it a go.
    http://www.harley-performance.com/harley-spark-plug.html
    Al
  • Phillthy
    Phillthy
    How many k's on the bike?
    Depending on the k's will change what you'll have to do.
    Yes you can use non Harley plugs in your bike.
  • allyoop
    allyoop
    Thanks for your reply.
    Bike's done nearly 33k
    I don't know it's history. It had just over 32K when I bought it
    I haven't ridden it much since buying it. I'm used to riding a LOW trumpy chopper.
    Can't get used to sitt'n so high. Don't like it
    The idea is to put it into a rigid when I can afford it
    cheers, al
  • Phillthy
    Phillthy
    Get yourself a service manual. It has all the good stuff in it you require.
    If you are going to alot of stuff yourself, get the electrical and parts manual as well.
    Best out lay I have made for my scoot.
  • allyoop
    allyoop
    Got it done.
    Put in 2.65 litres (Sportster and Buell forum) and still got a little coming out the breathers in the air cleaner.
    Had a few issues with the new air cleaner. First one didn't fit. Once I removed the plastic ring screwed into
    the carburretor on the air filter backing plate, I was able to fit a K&N filter.
    Might be my imagination. But it seemed a little more responsive with the new air filter.
    I've got a manual and "fix my hog DVD"
    Now that I've found my teflon tape, I'll change the primary oil over the next few days.
    Got to get a feeler gauge I can read before I can change the plugs.
    cheers, al
