Online: baldy1450
Ultima wiring kits
  • blacky
    blacky
      I am installing one of these kits into my bike, and am a bit concerned that they dont use relays for the high current draw stuff , i.e. headlight , start solenoid and horn. The unit is sealed so if one of these functions shits itself, you need to buy a new kit and rewire the whole bike
     Has anyone on here used these kits and know if they will last the distance without relays ?
  • twincam88b
    twincam88b
    No idea, what is the advantage of this kit????
  • blacky
    blacky
     This bike is a project-when I bought it it had no wiring to speak of , just ignition,headlight and tail/stoplight.
     I have installed the kit to give me a totally new wiring harness and also indicators, oil light , high/low beam , neutral light , etc.
  • grahamjb
    grahamjb
    Blacky
    They probably use transistoror SCR switching in lieu of relays which shouldn't be a problem
  • shifta
    shifta
    I used the ultima kit on my litech sportster easy to use havnt had any problems with, Im running a capacitor in place of the battery, joe hunt magneto and kick only, but I know a coupla other guys who run em with elec start and thay had no probz
  • blacky
    blacky
     Cheers guys, I ended up fitting four relays. one for hi beam , one for low beam, one for the start solenoid and one for the horn.  May be overkill but WTF
