Online: B0nes, speedzter
Road King Windscreen
  • barchem
    barchem
    Hi ,
    I am new to the bagger scene having traded by 06 Softail Standard on an 08 RK Classic . Love the look and ride of the bike especillay with the race tuner/ Vance and Hines 2into1 exhaust fitted - power is amazing compared to my 88 with power commander . The problem is the buffeting I am getting from the screen at  speeds above 80km/hr. I am very close to 6ft - previous owner about 5'8" - have tried a pillow under butt to simulate lowering the screen but little improvement - have tried squatting down behind screen much improvement but have also tried moving closer to screen which improved things - not sure when squatting whether it is the fact that I am lower or closer to screen. I wear a Nolan flipfront helmet and on the softail with no screen I experienced some buffeting but could at least have my visor open a notch to allow airflow but not on the RK with screen- heaps of buffeting plus wind noise. I have searched this site for information - any suggestion - do I need a higher screen or will the wind deflecting lowers assist.
    My plans are to start doing some longer rides with the handbrake on back hence the bagger but need the screen . One of the reasons for the RK is I can strip it down for local day rides but have the comfort afforded by a screen for weekends away .
    Any suggestions greatfully received
    Barchem - Hervey Bay QLD
  • Hoodaman
    Hoodaman
    Mate I have the same bike and im just an inch taller and I get no buffeting at all..........I even use the same helmet as you..........sorry i dont have an answer just thought that funny how just an inch taller can make the difference????
  • nobody
    nobody
    You might try clearview screens,the curve in the top of the screen deflects air away from the rider.BMW have been doing it for years   www.clearviewshields.com/shop/product.php   .They take a while to deliver,but a lot of good reports on the U.S. site regarding helping to solve the same thing you report.
    nobody
  • barchem
    barchem
    Thanks for replies- are any of you using the HD lowers and if so to what effect
    Barchem
  • gonzo
    gonzo
    Hi Barchem.
    Now, I'm a lot shorter than you. Actually I'm  lot shorter than most people. I look through the top 2" of screen and I had the same problem with buffeting with my HJC Symax flipfront helmet. It's much less of an issue with an open face, but I don't wear them.
    Anyway, have a look at the wind deflectors here:
    members.optusnet.com.au/gonzalesb/rkc/
    I'm really happy with the result. I think fitting something on the lower part of the screen/forks/crashbars is a good idea. The only problem with the HD items is, if we're talking about the same things, that they're big and heavy.
    Gonzo.
  • twincam88b
    twincam88b
    Howdy Barchem, funny thing is I have done the same upgrade, from a 2003 Softail to an 08 RKC. Love it, and I'm a screen convert. Reading your thread I'm thinking it may just be the helmet. I have both an open face and full face helmet. Used the fullface on the Softail for long trips in winter.
    Riding the RKC I find that the open face is fine, no buffeting at all. However I did try wearing the fullface helmet one day, and the buffetting was that bad I turned back home and changed helmets. I don't know why this happened or if it was just a once off with the weather conditions, but I now prefer the open face. I don't like the closed in feel of the FF, you feel more isolated from whats happening and what you can see.
    I'm about 5ft 10 inches tall, and I look over and through the screen.
    Cheers.............twincam
  • robert65
    robert65
    due to the ape hangers and the highway pegs my riding position fortunately prevents any buffer at all.
  • gonzo
    gonzo
    Hey Barchem,
    Simple test - While you're riding and you're getting the buffeting, try putting your feet on the top rail of the crashbar, just behind the indicators. If the buffeting stops or reduces a lot, you'll benefit from the air deflectors. If it doesn't improve - it's something else.
    Gonzo
