Used SERT wanted
  • Mainey88
    Mainey88
    I  have one, off an 06 Dyna have the CD and dongle etc send me a PM with some contact details I am up in Burns not far from ya.
  • grahamjb
    grahamjb
    Guys
    Have recently brought a 08 Streetglide and I got a sert with it. Is there any software that should have been included and if so, where can I get a copy?
  • grahamjb
    grahamjb
    Thanks Scotty - How do I PM you? My email is appended to this reply and if you could contact me by email I will be able to reply.
    I can't see any provision on this website to send PM's. I have a SERT that came with the bike and nothing else. I can make up cables (work in the electronics industry), I just need a suitable schematic. The reason for wanting the software is to see what can and can't be done with the SERT. I have reasonable experience tuning GMH Delco ECU's so am not new to vehicle electronics.
    It would be good to learn and play with the Street Glide
  • grahamjb
    grahamjb
    Scotty
    Have you tested the TTS software to check for compatibility with existing SERTS? There will probably be a checksum difference in the firmware between the SERT and TTS packages and I am curious to see what the SERT upgrade will be i.e. software or software and firmware.
    Thanks
  • grahamjb
    grahamjb
    Thanks Scotty
  • harleynt
    harleynt
    Hi Scotty
    I own a sert that i use on my 2005 fatboy
    I cannot find anyone in my part of the woods(darwin) that has any idea how to map using the sert
    How can I find out more about the TTS update for serts
    many Thanks in advance
  • kensim
    kensim
    that was a good thread.
