Baffle fell out of Hooker Troublemakes
  • strucweld
    strucweld
    A baffle fell out of my new Hooker Troublemakers, Will this do any damage while i wait to get another one ? Can anyone recomend somewhere to get a pair ?
    Thanks Jason
  • Deadly
    Deadly
    So whats it sound like? Sorry, but someone was allways gunna ask
    Damage?, what engine managment are you using. eg.Tmax WITH autotune should just about look after it I think but don't know for sure.
    Best whip the other one out and use heaps of twist on the grip just to keep things even during the meantime
  • strucweld
    strucweld
    Deadly, Its F$%^&&*ing loud, My ears were ringing after 5 min ride to work (very deep sound). I have no efi managment systyem ,Is this a problem ? I think i will take the other one out if it wont do any damage i will just have to push it down the road and around the corner to start .
  • kingchops
    kingchops
    I'd take the other one out while you're waiting for a replacement. Leaving only one baffle in will create different back pressure between the two pipes. Especially in a two into two exhaust.
  • weasel
    weasel
    You know you got the sound just right when you have to push it down the road to start it
    weasel
    I sell them, and it's not un conmen
