Online: Retroman
Changing Security Code Help
  • Hog Dog
    Hog Dog
    Does anyone know what steps I need to follow  to change the security code on a  2007 Street Bob as  I am stuck with the previous owner's code.   The manual I have is from the USA, don't know if this makes a difference or not but I have followed the relevant steps with no results.   Thanx
  • ubdead66
    ubdead66
    i kjnow scotty knows a fair bit of what u ask .Yer better of asking in the tech help forum he lives in there i believe
  • Davo2310
    Davo2310
    well i can only go by the 09 model but with the fob handy try this......
    1, turn ignition key... ignition-off-ignition-off-ignition
    2, press left turn signal 3 times.
    3, press right signal 1 time.
    odometer will display current pin number.
    4, enter first digit of new pin by pressing left turn signal the number of times u want, eg, 2 presses for 2 etc.
    5, press right turn signal 1 time. this will replace the first number.
    6, carry on with remaining numbers 1 to 9 can be used but no 0.
    7, when 5th number is recorded, turn ignition key off, before module rearms.....
    these need to be done fairly quickly.
    hope it helps
    Davo
  • 1elcys
    1elcys
    Probably not a good idea to put that in the public domain guys.
    Bikes will start going missing.
    I had a shitload of trouble doing this on my bike, but after much trial and error I found it was the first step (turn ignition key... ignition-off-ignition-off-ignition ) that was messing me up. I tried doing it quick, in between and slow...and one of them worked, but I can't remember which one :)
  • MickDB
    MickDB
    perhaps you were not holding your mouth right?
    I did exactly as I was told. Carrot up the backside, eyes crossed and tongue out.
