new hydraulic line
  • shfunky
    shfunky
    Am fitting forwards with a master cylinder for rear brake on my 07 bob so will need a new hydraulic line custom made, where would be the right place to start looking, I was thinking maybe a car brake specialist. What about fittings for each end ??  Any help appreciated.
  • shfunky
    shfunky
    Thanks Scotty, what do you mean by "plumb in" the brake line? I realise the micro would be on the rear of the  pedal somewhere.  Pardon my ignorance but what are "speed shops".
  • shfunky
    shfunky
    Thanks Scotty, I live on the south coast and we dont have performance shops (I dont think so anyway). I had a look and I know what you mean now, looks like a bugger of a job though. I was thinking the best way would be to cut the 2 wires to the 'sender' that is plumbed into the fitting and then lengthen the 2 wires, then get the 'sender' re-plumbed when I get the new line made up. What 's your opinion? The manual shows the sender but doesnt mention it anywhere.
