FXD Quick Release Docking Hardware
  • Sponge Boy
    Sponge Boy
    Is it possible to add docking harware to the struts of the FXD/FXDC/FXDL/Streetbob variants without having to completely relocate the rear indicators ?
    I know a guy who has a Softail where the the rear indicator "wing type" stalks have been removed and replaced with a more basic stalk which includes the docking point.
    Could the same thing be done with the FXD ?
  • kingchops
    kingchops
    I think moving the indicators is done in order to fit things like saddle bags, not so much for the docking hardware.
  • kingchops
    kingchops
    Yes, the docking hardwear just replaces the two bolts on either side of your rear fender struts.
  • Purnong
    Purnong
    Below is how I did it on my 08 FXDC, Sorry for the crappy phone pics
    If I remember correctly I had to buy the indicator relocation kit which is basically longer bolts that remove the wing type mount and replace with those below
    It was a pain in the arse working out what I needed because the harley site was no help
  • Sponge Boy
    Sponge Boy
    Purnong, yeah that's whay I'm talking about.
    Do you use a quick release luggage rack or a sissy bar arrangement ?
  • Purnong
    Purnong
    I use the detachable sissy bar
    I can dig up the part numbers you need if you like
  • MRPIG
    MRPIG
    For what it's worth, here is my 2 bob.
    I got an FXDL, and i got the detachable sissy bar, and like the above pictures show, the indicators are on the end of the cam bolts.
    This is an easy conversion to do.
    However, I have now installed ghost brackets with bags of course, and had to move the indicators elswhere.
    They are now located either side of the rego plate, with a couple of brackets I manufactureed myself.
    I had to cut the indicator wires , and resolder them after mounting the indicators.
    Oink Oink...
