Online: Retroman
Forward controls for Street Bob
  • kingchops
    kingchops
    Anyone fitted the Kuryakyn forward controls for the '06+ Dynas?
    I'm keen to rip the mid controls off as soon as I get the Street Bob, I like the that the Kuryakyn controls come with a cover for the mid control pin and a securing strap for the lever because I'm not taking that sucker off.
  • OSP1340
    OSP1340
    I do know alot of guys on the American forum have changed to the Kuryakan forwards and like them alot.
    I had the HD forwards put on mine before I picked it up.
  • 1elcys
    1elcys
    Same here, just got the HD ones fitted before I picked it up pity they don't come in black though.
    They said free fitting, so why not and I hate mids.
    congrats KC....
    I'm still running mids, but also have cruising pegs and I'm 6'2"...... still want to put forwards on but cannot find anything i like that are at least 2.5" extended and in black and at a reasonable price, like under $US500
    looked at the photo KC... gave you a bum stear... your cruising pegs are adjustable.... loosen bolt, adjust and tighten!!!
  • Daggs
    Daggs
    got the HD's, was worried about not being able to throw it around like i did with the mids but thats not a problem at all, thrown her around heaps, even more probably since had the forwards on and no more cramps in the hips like i used to get even days after a ride with the mids.
  • grafpak
    grafpak
    het kingchops how is the dyna going?
  • kingchops
    kingchops
    Yeah, Dyna is going great went out for the first decent ride this morning with Scotty and Loftybob, bike went great. I'm starting to feel comfortable on it now, and I rekon I'll stick with the mid controls, they don't feel too bad.
  • TNT
    TNT
    Hi KC congrats on the Dyna mate when you do change to forwards make sure if you are getting non HD that it's got a decent gear shift linkage I got after market one's for mine & after a short while the linkage rattled to bits so I put a HD one on it ( $160 later ) no probs now.
