Online: tussuck
09 FL Rear Cyl Cutout
  • EGStreem
    EGStreem
    Well it got a bit warm here yesterday, so I decided to activate the engine idle management as I was burning up in traffic.
    I had used it during the week, the hype says you will hardly notice it, and I didn't.
    Anyway it was 38 yesty and we were doing a lot of stop start stuff in the traffic and I figured it was doing its stuff. However we went round a friends place later (even hottter about 40 odd,) all of a sudden at the lights and I am melting and hallucinating with the heat, my bike suddenlly sounds like a single . It was actually a nice sound. So I am thinking maybe you have to be on the verge of heatstroke before this thing kicks in however between the midday ride and the arvo ride to my mates I disabled the flapper valve in the exhaust.
    So I am not sure the disabling of the flapper valve has made me notice the rumble of the single fire rear cyl cutout better. Or does it have to be over 100 degrees before it works
    Has anyone else been in high heat and noticed the cutout system in operation yet.
    Hey LoftyBob, you might be trying this soon out as you get Perth weather about a week later eh!
  • LOFTYBOB
    LOFTYBOB
    This feature has been decativated in the Ultra, with the TTS tune in now she doesn't run anywhere near as hot as it did before the tune went in.
  • twincam88b
    twincam88b
    I would rather ride in pouring rain than 40 degree heat.
  • EGStreem
    EGStreem
    Scotty, I have sent you a PM.
  • PigironBob
    PigironBob
    Jeeze I hate it when you guys PM becuase there could be good info that will help me and others not being posted.
  • Fr3d
    Fr3d
    For those with 08 Road Kings, you can have the parade mode turned on as well. Sounds like exactly the same thing. When you get in very hot engine conditions, one cylinder turns off. Ive never had it turned on. Any one used it on an 08RKC?? With this warm weather we have been having I might have to think about it.
    I agree with Scotty though, if the bike is getting that hot its time to get off the bike and turn it off. But then again why should I have to do this on a bike that is less than a year old? I can understand a clapped out holden going up Bulli pass in the last few days boiling over, but not my RK. When I bought the bike the dealer did not say to me that I would not be able to ride around town or in traffic, in hot weather above 35 degrees. If they were up front about the heat issues, maybe I would have got something different.
  • LOFTYBOB
    LOFTYBOB
    The rear cylinder cut out feature was never meant to be an engine safety device, it was always meant to be a passenger/rider comfort feature. So it activates far earlier than would be if it was used as a engine overheating device. Reading the features lists of the American HD site, it says the cut out was featured to reduce rear header pipe temps when in heavy traffic. Just because it's activating, doesn't mean you are doing your engine any harm.
    Still, it would pay to richen up the AFR's though.
  • Hoodaman
    Hoodaman
    How does parade mode work on the 08's????
  • aussiesport
    aussiesport
    hey guys just a note on the heat thing when they test the engines for heat cycle ,they lock it in a sealed wall open top shed and leave it idle for 10minutes ? then go out and ride the thing for another 10minutes flatout lock it back in the heat chamber ..and so on for 10 times ? as for it cutting in ,it is very noticible and seems to work for comfort a little ,but when it hot air temp its freakin hot anyway :(
