Online: Stuart
Cleaning yer rim
  • gonzo
    gonzo
    Thought that might get your attention.
    Anyway, I just put new tyres on the 07 Road King Classic. First set, 18500K, whitewalls.
    Took the wheels to Frasers to get fitted. Brought them home and admired the REALLY WHITE whitewalls. I'd forgotten how white they were when new. Then I looked closely at the rims. Grubby. Very grubby.
    So tell me - how do you get your rims clean in between the spokes when the front wheel's got two disks and the back wheel is equally inaccessible because it's got one disk and one belt sprocket? The grot appears to be from the disks.
    Also, how do you clean the centre of the hub (the aluminium bit in-between the spokes)?
    None of my previous bikes has been this difficult to get into.
    Is there some magical spray/potion/spell????
    Gonzo.
  • Hoodaman
    Hoodaman
    I use the HD spoke brush and my wife...........well she uses the spoke brush but it works a treat on the whole rim on my King.....Also she has really little tiny weeny hands that fit in the bad spots..........
  • gonzo
    gonzo
    Hey Hooda,
    You don't have a photo of this spoke brush, do you?
    Do you use any particular cleaning solution with it?
    I hope it's not abrasive on your wife's hands...
    Gonzo
  • Hoodaman
    Hoodaman
    This is it mate and does the job real well all over the rim..HB is a greenie so she only uses HD biodegradable stuff and it works well but i cought her out using sum acid spray from MCA..
  • twincam88b
    twincam88b
    The above brush and a bike lift does the job.
    Not bad mileage for the Roadking tyres, is that front and back????
    use a baby's bottle brush as well as toothbrush and various other nick nacks like thick sports shoe lace wraped round couple times and pulled back and forth.... all are long hard tedious jobs so bike lift helps
