Online: Hilly, speedzter, Merv
Sissy Bar Injuries ?
  • Sponge Boy
    Sponge Boy
    Has anyone had or know of anyone else who's had accident related back injuries resulting from a sissy bar ?
    I've always been a bit aprehensive about fitting one, fearing what would happen to my pillion in the case o f a rear end collision.
    Youre opinions/ experiences will be appreciated.
  • Finny
    Finny
    Sponge Boy i think with or without a sissy bar , A rear end collision would in some shape or form affect your pillion ,
  • twincam88b
    twincam88b
    depends if you are sitting at the stop sign and a road train forgets to stop behind you or it's just a pensioner in a gopher.
  • kingchops
    kingchops
    If I ever got hit from behind on the bike, I wouldn't want a sissy bar on there. Use them as little as you have to, that's why detachable ones are a great idea.
    My 0.02c worth.
  • 1elcys
    1elcys
    Try an think positive otherwise you will want 24 hour bublewrap.
  • whiteyluvsrum
    whiteyluvsrum
    fuck pillions, pillion at own risk.
  • Sponge Boy
    Sponge Boy
    A top box is one thing; first of all it's much wider and blunter than a sissy bar. a sissy bar is another.
    I'd be concerned about my pillion breaking her back if hit from behind.
  • PigironBob
    PigironBob
    Seen a couple take of from some lights here a few years ago, he went, she landed on her arse and nearly got run over from the car following. No sissy bar fitted. She was not happy I can tell you, should have heard her calling him all the names under the sun.  Wonder if they have a sissy bar now???
  • whiteyluvsrum
    whiteyluvsrum
    spokie dokies would of saved ya!
  • lil_bitch87
    lil_bitch87
    my dad almost dumped me at a set of mights, so from then on u started going with my mum until he got one. no way would i go more than 100k on the bike without a sissy bar. why would you be worried about her safety thats just a bad omen, instead think about her comfort. as everyopne has said, if you get hit from behind you are going to have dramas, at least if the bar is there it might hold you to the bike a bit better than ending up in the cars grill. i would go with a detachable sissy bar for sure.
  • Fat-Boy
    Fat-Boy
    For what it's worth, more chance of dumping your pillion than getting hit from behind. It's a gamble either way - lets hope it never happens.
  • Soapbox2627
    Soapbox2627
    Pillion, what pillion?
