Online: B0nes, John.R
Street Bob Engine Light
  • syco_bob
    syco_bob
    18 years ago
    Hi,
    I have installed a PCIII on my 06 FXDB.  Has fixed the tuning problem I was having but now after experimenting with a few different maps, I have noticed that the engine light comes for a few seconds once the bike is first started.  This is after the initial ignition engine check.  It stays on for about 3-4 seconds then turns off and never comes back on.  The owners manual just says to see a Harley Dealer.  I was wondering if any of you have had this or know what it could mean.  The bike seems to be running fine and this didn't occur when I first installed the PCIII.  I have tried 5 different maps and it has only started doing this on the 4th and 5th.  Any comments would be greatly appreciated.
    G.
  • BACAMICK
    BACAMICK
    18 years ago
    are u clearing the old map b4 you put a new1 in ? think it was somthink like reset value maps cant realy remember, the thundermax will fuck u up if ya dont clear it all aswell learnt that the hard way
    i have a nice map here if u want it
    high flow pipes-SS etc
    high flow- AIR C
    disconected o2s, set up on a dyno i got from some dude in the usa
    nil poping
    origanaly was this map
    2006 Harley Davidson Dyna *Advanced Map*
    Thunderheader 2:1 exhaust
    Screamin Eagle air filter
    Stock ECM
    Dynojet O2 sensor eliminators installed
    Table 2 is front cylinde
  • syco_bob
    syco_bob
    18 years ago
    I did some research on this over at the USA HD Forums and found that alot of owners had this happen to them and 9 times out of ten the cause was the ecm throwing out a faulty code and that after a bout a month the engine light stops coming back on and never damaged the bike. I downloaded the self diagnosis codes just in case I ever need them. The US forums is a great source of info.
    I have never cleared an old map from the PCIII, I thought it did it automatically. The only reset option is the "reset button values" button in the "Tools" menu but i dont know what that means so i just dont use it.
    Last night I loaded map "M807-005" which is the SE slip ons, SE A/C and stage 1 ecm. The bike ran fantastic this morning on the way to work. I would say the best map I have tried so far. Its quite possible then that I do have a stage 1 ecm since its running so well. i thought I had lost it when I rewired the indicators.
    BACAMICK: I would love try the Dyno tuned map also. Are you able to email it to me? gant@bigpond.net.au
  • BACAMICK
    BACAMICK
    18 years ago
    DONE    SYCO_BOB
