Online: Soapbox2627
2007 fatboy rear end on 2005 fatboy
  • harleynt
    harleynt
    Hi all
    Is it possible to fit the rear end of a 2007 fatboy (with 200 rear tyre) onto a 2005 fatboy using 2007 swing arm and wheels.
    Many thanks for your reply
  • alchemist
    alchemist
    Was it an easy conversion grumpy?
  • petermac
    petermac
    G,Day Grumpy . I,m trying to do the same 2009 fatboy 200 rear wheel&swingarm onto a 2006 fatboy . went to put the 200 swingarm in and found it was 10 mm bigger than the 2006 (should have ran the tape over it first ) . Did you have the same problem.  I was about to spred the frame and decided to look for more info so here i am .  Any advice would be great thanks  Petermac
  • Ando
    Ando
    mate grumpy ain't here no more and that thread is nearly 4 years old
  • petermac
    petermac
    new to the forum ,dont know my way around it yet ,as they say you never stop learning i,ll try better next time
