Re build is on the way
  • Phillthy
    Phillthy
    Well I have ordered all the parts I think I need for the rebuild.
    Will just have to find some one to bore out the jugs here in SE QLD. Any ideas on who is good?
    Will also have to get the cam bearings reamed after I put the new ones in, may have to go to Wackers for this (ouch).
    I have to take the motor apart again to get the cam bearings in which is a bit of a bugger and will add days on the job.
    Glad I have split it before and know what I'm up against.
    It should be back on the road the middle of Feb all going well.
    Going on holidays in March and taking it away with us, so it better be finished.
  • toxic
    toxic
    well hop to it young man, times a wasting
    good luck with the rebuild................
    Gee you broke it months ago,, what have you been doing?
  • Phillthy
    Phillthy
    Penance around the house.
    Had some work to do on it the I let go last rebuild.
    Mostly finished now, so it's on with the bike.
  • Fat-Boy
    Fat-Boy
    good luck with it and I hope all goes according to plan.
