Online: bikenut57, B0nes
HD High Output Bulbs
  • Jasonbb
    Jasonbb
    G'day all, just wondering if anyone has brought these HD bulbs (67074-02) any thoughts?  They seem a little expensive at $33.66 after discount compared to other bulbs available.
  • toxic
    toxic
    a bulb is a bulb is a bulb, there are plenty of quality bulbs on the market, Harley don't corner the market on em, my choice would be, shop around .....
  • Phillthy
    Phillthy
    Just watch the high wattage ones.
    They will melt the wires at the connection.
  • Jasonbb
    Jasonbb
    Doesnt seem like anyone has used them, I wanted xenon but its really expensive and can be a problem if you dont change the whole assembly.  I really like the light output from my Honda Euro.
  • Jasonbb
    Jasonbb
    I ended up getting the HD bulb, its pretty good if anyone else is interested.
  • SuperGlide
    SuperGlide
    Noticeable difference over stockie?? is it whiter??
  • Jasonbb
    Jasonbb
    Yes whiter, you can see the colour difference between to small globe at the bottom of the headlight, does light up better in front. Its expensive for a globe but in the sceme of things not enough to worry about.
    I dont know what the difference is between much cheaper globes, I'm sure HD Australia is making a killing.
    BTW beeza where is the clip in your aviator from?
  • lucky
    lucky
    funny about those harley globes ! new bike. two weeks , globes blown , put cheap globes in , no problems for two years ,makes you wonder !!!
  • Jasonbb
    Jasonbb
    Come on out with it, its got to be the interview before she gets busy.......put us out where do we find it
