Online: beaglebasher, Nino, Hilly, speedzter
replacing headlight - need advice
  • toxic
    toxic
    G'day all, am about to swap out the headlight on the nightster for a better looking one, question is, the factory one has a built in parker light, but the replacement one doesn't, so, will it be fine without a parker bulb , or, should I use a headlight globe with a parker light, ( 3 filament globe ) in the new one, just looking to ensure I get it right the first time around.
    Any advice will be greatly accepted.............. thanks in advance .........
  • toxic
    toxic
    OK I've worked out a solution, from what I found out, if the bike has a parker light from the factory then it should have one at all times, could be for incase the main headlight blows, you would still have a light to show there was a vehicle thee ???
    Anyway, there is a small flat area in the new light which I will set up a white LED & use the oe wire to set it up.
    Now I just have to get a small bracket machined & Bob's ya Aunty
  • shfunky
    shfunky
    I replaced my headlight with one that didnt have a "park light", just didnt worry about it, have had no problems, I reckon that little light looked shit anyway.
  • MapleLeafs
    MapleLeafs
    If the headlight blows on a night ride, stick a flashlight in your mouth and continue on <img src=" align="absMiddle" border="0" src="/DesktopModules/NTForums/themes/_default/emoticons/smile.gif" />
    OR carry a miner's helmet with light attached  - oh and AuStandards sticker and lining patch ;)
    Hay Toxic , Iv'e got a New range of Headlights coming in soon. They Start about $280.00 and range up to $500.00 and all are ADR Aproved and have a Parker.
  • toxic
    toxic
    Thanks Walka, got it sorted, have finished doing the set up, now just have to get it powder coated black to match the bike, hope to have it done for the Silverwater bike show
  • toxic
    toxic
    OK finished the headlight swap today, adapted the factory wiring to suit the new one.
    Old one front view.
    Old one side view.
    new one is much longer.
    so it sticks out further.
    new one front view.
    All things considered I think it looks ok, will have to have a ride up the old road one night to see just how good it is.
    The Light looks good in Black , I would try and get rid of the Eyebrow, but again Looks Good
  • grafpak
    grafpak
    looks good, do you want to sell the old light?.cheers..dc..
  • Hoodaman
    Hoodaman
    Good work Tox.lookin goood..........big headlight...saddle bags....ur on ya way to a RK mate......lol
  • Fat-Boy
    Fat-Boy
    Hey Toxic, that looks really good....all worth the problems you had getting it fitted eh?
  • gonzo
    gonzo
    Yeah, what you need now is a nicely blacked-out windshield.
    Gonzo
