Baffle removal
  • 86juc
    86juc
    Has anyone removed the baffles from screamin eagle slip on's, ive removed the 2 bolts that seem to hold them in but still can not remove the baffles. are the welded in or do they need a little force to be removed.
  • kingchops
    kingchops
    I tried it with mine a while back and found the same thing. I recall reading someone that did do it and apparently they are pressed in with quite some force, they weren't easy to get out.
  • brucecul
    brucecul
    i did undone the 2 bolts took a bit of effort to losen them . sounded like shit without them
