help deciding on new shocks
  • lil_bitch87
    lil_bitch87
    Hey guys
     i have an 07 XL1200C (1200 sportie)
    and i want to change my suspension to somethin that rides a little nicer.
    i have been looking at B&T manufacturing, smooth ride air shocks http://www.btmfg.com/
    i was wondering if the air suspension rides better than your normal shocks,
    i dont really care about lowering for looks or anything, i just want it to be more comfy on rough roads.
    other shocks i was looking at were progressives, would they be as good or betrter than air?
    thanks in advance
    charls
  • sime69
    sime69
    reckon you'll find most aftermarket shocks are better than the "agricultural" stock HD ones!
    From what I've read, an air ride would be much more forgiving. I've ridden a Road king with them on, but only around town so didn't notice much difference. Did you notice the BT ones are $569 EACH?? They'd want to be bloody good for that money!
    I don't have either of these, so can't comment, but Progressive are popular for Sporties and Dynas, and the most talked about big dollar ones would be the Fournales brand. There's also a company in Albury called Ikon Suspension who make what used to be Koni shocks.
    If you have the stock seat , you might find changing that will also help comfort levels on long rides
    Sime
  • Robbo
    Robbo
    Got to go with Sime69 anything is better than stock, I whacked a set of progressive on my FXSTC and noticed the difference straight away, firmer in the corners and no bottoming out.
    I have Ikon's,,,, Great Shock
  • lil_bitch87
    lil_bitch87
    Hi Robbo
    a little confused, my mum has a FXSTC, (softail custom) it has a mon shock, how do you fit a set of progressives to a softail?
  • lil_bitch87
    lil_bitch87
    lol i dont think there is hope of that, mums bike rides wonderfully (she is really happy with her suspension) i am trin to get somethin to make it ride better but even i have doubts if i can make it ride that well.
    thanks for your advice and clarifyin the STC, regards
    char
