Online: bikenut57, Hilly
foot pegs
  • seaeagle
    seaeagle
    folling on from the post i hiacked, about the placment of footpegs, i moved it to the front hole in the brake thing, feels much betta, but now theres no "stop" for the pedal,
    the hole that is above the spring in the picture is where the peg was and it had a stopper bolt thing in it so the brake pedal woulnt come back to far and the plunger thing cant fall out of the brake thing...... fark i should get a parts book and learn the correct name for things
    the pedal has the hindged bit , whats that bit called and where can i get one from?
  • The Don
    The Don
    Hi Mate,
    Replace the brake pedal stop with either a piece of angled stainless bar (drill a 3/8 hole and fit where the footpeg mount was.), or a socket, a 1/2 inch should do,(you might need to use an extra length one ) with a 3/8 bolt through it and the bracket. And use a nyloc nut.
    Should do the trick and look OK.
    Cris
