Online: GGUser260, spartamaxsuse
Moisture in speedo
  • Hoodaman
    Hoodaman
    ive learnt to live with it mate...
  • ubdead66
    ubdead66
    ditto for all that was said
  • Mainey88
    Mainey88
    +++++1 have to get used to it but it does disappear when ya get out and ride
    apparently they are still working to solve the problem. If you push the point HD will support a warrantly exchange, but only once. Replacement guages will likely suffer the same fate!!!
  • twincam88b
    twincam88b
    Yeah I've had the same problem
  • Tbolt
    Tbolt
    Seems to be an all to common problem, mine does the same, you are definately not alone with this one.....
    TB
  • Finny
    Finny
    95 roadking and it always happen's, I was told not to stress as it happen's to newer model's
