help with cam choice
  • hellboundpig
    hellboundpig
    needs some help with cam choice sticking with stage 1 twin cam 96b for the moment just need a good cam that pulls hard trough the torque range and wont cause reliability issues . cheers hellbound.
  • Robbo
    Robbo
    Hey Piggy,
                      take a look at Valve Spring thread in workshop, I've been talking to  Scotty about cams and set up. For me I like to go into depth and understand why it works and how it works and Scotty has been a big help with information on what I can do and can not do with a stock 96cid motor. Another site you might what to look at is www.nightrider.com here they give some advice on different upgrades for our engine, hope I've helped in some way.
