Road KIng - how bad is the windscreen?
  • berms
    berms
    Getting a tourer this year, just wondering what thje new RK was like with the screen on?
    Does it give you buffeting?
    Are there better aftermarket screens for this bike?
    Thanks
  • gonzo
    gonzo
    Hi berms.
    I have an 07 RK classic. The general geometry of the latest looks pretty much the same from a wind point of view. I have fitted wind deflectors (which I made myself) as per the following:
    members.optusnet.com.au/gonzalesb/rkc/    and select the Wind Deflectors link.
    They make a huge difference to the buffeting and noise. HD make large chrome tapered deflectors that attach to the mountings for the aux lights. I guess they do the same thing, but they weigh a ton.
    Gonzo.
  • rkc07
    rkc07
    berms
    i travelled to melb from wollongong with windscreen on ... sat in a nice pocket and had bugger all buffeting ..if any at all ..made the journey very easy and didnt hop off tired at all at the end
    I am 6'2" so look over the screen as well ..get a little buffeting on the helmet but nowhere near the same as no screen
  • twincam88b
    twincam88b
    Berms, I have the 08 Classic and I'm about 5' 10 tall and I find the screen suits just fine. In fact I'm a screen convert. Sometimes I take it off for short trips into town, but any longer trips and I wouldn't be without it. I find that I look over and through the screen, depends which part of the road you are looking at.
    I wear an open face helmet. I did try the screen with my full face helmet and I found that it did buffet a bit, annoying flapping from helmet. Go figure......might be the brand of helmet, who knows............twincam
  • gonzo
    gonzo
    Berm,
    Sorry for the delayed reply - I've been away.
    Yes, the buffeting was not acceptable - mainly from a noise problem, rather than actually bouncing my helmet about. The deflectors fixed it. I went for a moderate day ride without the screen a few weeks ago, and quickly put it back when I got home. I'm a convert too.
    HOWEVER, TC88b raises a good point. I wear a full-face and they definitely make it worse. Also, I'm 5'3", and I look THROUGH the top 2" of screen. So, my head's in quite a different place than rkc07, or tc88b, and probably your good self, because most people are taller than me....
    The test ride should tell you the answer - just make sure you travel 80+kph. In any case, if you find it's a problem after you buy, you can always get the HD deflectors or make your own.
    Gonzo.
