Online: B0nes, John.R
D&D fatcat and the crap ome headers
  • BACAMICK
    BACAMICK
    18 years ago
    got me new pipe today , thanks to me missus buying me somthink i can use 4 once b4 xmass
    im realy amazed at the workmanship on there FATCATS, i was amazed to see that they get inside the headers and clean n polish all the welds up, looks like a nice port job  i no my V&H were debured , but polisht they were not , now i can see how each pipe is hand made up and dynoed, now the differance between wat i thought were great as ,SS sliopons with the stock header, is no comparison , most of u no ive got a fair bit of HP , but to do a simple pipe swap and feel the differance is quit remakable on a bike that is already up there , WISH ID LISTEN TO STEVE B4
    now the stock headers on the 07 are real shit inside , ya all no the crossover right?  , well they stick inside the pipe [1 is 25mm , the other is 32mm]  inside , its gota rob ya of some HP ever on a stock bike , if uve all read how DOC got , think it was 3HP by removing the flap thing in there , surly removing the flap and the left over crossover tube could gain ya 5 HP on a stocker
  • BACAMICK
    BACAMICK
    18 years ago
    sticks , if i can get 120hp that be great  got the bigger injectors comming aswell as ur probly aware how loud is ur pipe mate , after riding to town last night i think the thing is way to loud, crackes lots during gear change when its in the back of stage , gets real dromie aswell , how can i be sure its a fatcat and not a borzilla ??
    true duals rk i recon a mates got them , fuck there loud aswell
  • czarek
    czarek
    18 years ago
    Hi Bacamick.
    Any chance of you posting some pcks of your pipes?
    Me got a 08 softy custom and want to improve sound and performance. Saw a "Screaming Eagle II" slash pipes yesterday on a similiar bike and loved the look, but they were 2 separate pipes. Would love to see yours for comparison.
    ta
  • BACAMICK
    BACAMICK
    18 years ago
    CZARKE look here http://www.danddexhaust.com/catalog/harley_davidson/index.htm dynas look differant to the softys when there put on
    not yet KARL, bugger aust post
    cant find a pic of ur baffle under ur build ?  might have to get 1 sent over, recon its deff a cat n not a borzilla, just expected it quiter than it is , had the big radious on the train and recon they were quiter than the fatcat
  • BACAMICK
    BACAMICK
    18 years ago
     thanks mate for the pic , mine is deff not like that , its open , looks like a vh baffle with the angled holes in it .ill pull it out n see if it can be wrapt
  • BACAMICK
    BACAMICK
    18 years ago
    KARL/STICKS, would u say that the quite baffle is the same as the standard but without the tin skin on it ?
    could i cut the outer skin of it and wrap the sucker ? or do the holes inside turn around and face the flow of gas ?
    if not ill get onto GMR
