Online: Bullshark001, Stuart, reeltor70, Hilly, Rextheute2022
question help advice
  • Night Train Rex
    Night Train Rex
    G'day all this is my 1st post not including intro post so be gentle hope I'm in the right area anyway here is my question
    Had to take the train to melb the other day (1st sevice) pissing rain and yep you guessed it wet weather pants hot pipes need I say more
    any  idears on getting the crap off without damaging the nice shiney bits
    I did the same thing a few weeks age , I tryed lots of stuff including Oven Cleaner , nothing worked , in the end I had the motor running to heat the Pipe up and then hit it with a Polishing Mop on the end of my Drill. Worked great
  • Night Train Rex
    Night Train Rex
    Calabos have tried the thinners had no real effect, think I will try the warm pipes and polish mop idea of walka and then the fine steel wool as a last resort thanks guy will let you know how it goes
  • MickDB
    MickDB
    try acetone .... it should break down (melt) the plastic....
  • Tapey
    Tapey
    If you are going to use steel wool make sure you use the stuff in the hardwear shops that people use on timber furniture, as it is real fine. You can get different grades of it. I use it on my front rim and it works well.
  • Night Train Rex
    Night Train Rex
    Well tried the polish mop on hot pipes got some off but not completely so time to try the steel wool so off to bunnings for me    well the steel wool worked a treat back to brand new and no scratches thanks guys
