Online: Bullshark001, Stuart, Hilly, Rextheute2022
Rattling Fuel Cap
  • Fat-Boy
    Fat-Boy
    Hey mate that could be your brain rattling...are you sure it's the cap  if it is the cap try holding the plastic bit and twist tighten the chrome bit.
  • MapleLeafs
    MapleLeafs
    I was gonna go a rubber band temporary idea... or even blue-tac :)
  • Bobtail
    Bobtail
    Hey Stix ya should get yourself a Softy mate..........Smooth as silk and not a hint of a rattle even with a loose cap
    But then again it might keep ya awake on the Nullabor
    Bt
