Online: beaglebasher
Internal Wiring T-bars 09 Dyna
  • FXD09
    FXD09
    I'm probably asking a question that has been asked a hundred times already but just want some advice on the best/easiest way to run the wiring through the bars where to disconnect it from etc. you could say I'm definitely a novice but am keen to have a crack at it gotta learn somehow Cheers
  • FXD09
    FXD09
    Cheers mate about the same story here with the dealer I will see how I go
  • Hoodaman
    Hoodaman
    do it Noit.........they really look smashing on there
  • Hoodaman
    Hoodaman
    Ur right TNT but i was having a cup of tea at the time.....
  • FXD09
    FXD09
    After many hours much swearing, and a hand from mate who is an auto lecky because I suck at soldering and pretty much all things electrical. The son inlaw and I finally got the bars finished.Will post pics soon . Cheers for info posted to my question.
  • FXD09
    FXD09
    Finally took pics
  • Nibbla
    Nibbla
    I recently did internal wires on my 08 FXSTC with Burleigh T bars, instead of using steel wire I blocked the 2 holes on 1 side of the bars with tape, then taped some light string/wool to the end of the wiring loom, feed the string into the hole with compressed air up its ass, it blows the string through the bars & out the hole in the riser, then pull the wire loom through with the string.
    Cheers Nibbla
  • sime69
    sime69
    even easier - use a vacuum cleaner to suck some fishing line through the bars first................. then attach the wires to..................... the line with electrical tape and pull through...................................oh yeah - ya might have to lube the wires first with WD40 or similar.
    sorry for the pauses....I keep checking out the girl in FXD09's signature....phwooar!!
  • Kovacs
    Kovacs
    Available through out Australia, are the Namz wiring extention kits to suit all H-D Models, these kits have all the colour coded wires soldered and pinned ready to install into the connector plugs. The tools to push these wires out/in are also available. It will certainly make the job easier.
  • Wingy
    Wingy
    FXD09, what is the make of your bars, thats the best I have seen yet with the speedo mounted on the bars..
    I would love a black set for my glide...
  • FXD09
    FXD09
    They are from Burleigh Bars
  • FXD09
    FXD09
    original speedo just got a hd chrome bezel from the dealer
