Online: Merv
How big can I go with Cams
  • Fr3d
    Fr3d
    Anybody know how big can I go with cams for a 96 cube big bored to 103 without doing head work? I have a 96 cube bored to 103 with SE flat tops.  Currently running 211 cams, SERT, SE mufflers and SE air cleaner.
    Thanks
  • Fr3d
    Fr3d
    Thanks, I will go on line and have a look at these Andrews cams. Still deciding whether is should go 2:1 or duals with good slip on's though.
    Fr3d
  • nobody
    nobody
    You can run up to .600 lift without headwork,but what particular cam will work for you depends on what it is going into and how you ride and whether you want the most out of the lower/mid range or mid/upper range.Most peoples problems begin when they overcam the engine.Bigger is not always better,so choose carefully.
    nobody
  • Fr3d
    Fr3d
    Thanks for the input guys.
    I am not sure which direction to go yet but this is all good.
    I wish I had done my due diligence before I had my current build done.
  • hellboundpig
    hellboundpig
    skulznflames can have the list of parts needed  to install a set of woods cams cheers.
