Timing Cover Replacement
  • dugga
    dugga
    Was just wondering if there is anything special involved in changing the timing cover?
    Will anything fallout / leak when i remove the cover?  Or is just simply two screws ( an o-ring i suppose) pop if off and install new one?
    Thanks in advance
  • dugga
    dugga
    Thanks Retsurht,
    Can add a timing cover to my christmas list!
    As long as he doesn't touch the mekor flange with his screw driver and blow all the fuses, or put the tuppets back in upside down when the legpuller unit slips down.
  • dugga
    dugga
    WTF?  Should i not try this at home
  • grafpak
    grafpak
    two minute job nothing there on newer models...
    Online I find myself risking one relationship to try to entertain the masses, while in real life I usually piss off the masses to defend one guy...though every now and then I forget which world I'm in :P
  • Sumpoil
    Sumpoil
    As per usual everyone has just glossed over the importance of the HD Design Engineers change to this particular area of the motorcycle, which I shall now rectify... Ahem...
    This cavity is an excellent place to dry out slightly moist stash, especially if you are headed interstate... ...
  • 1elcys
    1elcys
    Hahahaha Sump shhhhhhhhh!
