Online: Hilly, speedzter
thundermax base maps
  • hellboundpig
    hellboundpig
    I was wondering what is a good base map for a twin cam 96b softail with k&n highflow air cleaner ,vance&Hines big shot staggerds with quiet baffles.
    with thundermax autotune module any help would be appreciated screwd up my maps.
  • PigironBob
    PigironBob
    Start with 401.
  • hellboundpig
    hellboundpig
    Thanks pig iron bob 401 works well as a base map took it for a blast wow no decell popping and gurgle anymore dropped the idle a bit and it sounds sweet .
    fitted a thundermax to a 09 fatbob with my brother we moved the alarm module and my mate has the data link cable atached all the time what a sweet job he did it  better than factory my mate was stoked .cheers again hellboundpig.
  • PigironBob
    PigironBob
    What map did you use on the Fatbob?
  • hellboundpig
    hellboundpig
    Pig iron bob  thundermax was pre mapped by steve at heavy duty motorcycle ,i will check with my mate when hooks up his data link we will get the map for you .
    it has big radius 2 into 1 thunderbird aircleaner and  sounds  really nice.
