Online: obisteve, clackavosticus
ROBBO
  • Gav
    Gav
    18 years ago
    Just a quick note Robbo,
    Got my bike back from dealer last Friday just in time for the Ravenswood toy run and after that I installed the pipes auir cleaner and tmax. Just wanted to say thanks for your map recommendation. ive run with it and it seems great, no popping and sitting on approx 13 to 13.5-1 AFR. Didnt quite folow the instructions for the install but workd it out anyway.
    Gav
    Oh btw  the electronic plug in for the flap in the orignal air cleaner did you just tie it off? Thtas what ive done and it seems ok to me.
    Still playing with the software supplied and not quite sure if i have it in learning mode or not....
