SEST Maps
  • wildchild
    wildchild
    I have a copy of the software for the old SERT that has a 176AE104 Map.
    Loaded in my bike is the SEST 176AE105 Map.
    Now the new 09 Maps are 176AE106
    My question is, what is the difference with the Maps, I can't see anything between the SERT 176AE104 and SEST 176AE105 only file format as for the SEST 176AE10are there any improvements in the maps over the 176AE105 or are they the same.
    Are the 09 dongles different from the 08 ones.
    Has anyone got the 176AE106 Map.
    WC
  • wildchild
    wildchild
    Scotty, Thanks mate..I'll post the differences shortly.
    Software would be good if I can get a copy.
    WC
  • wildchild
    wildchild
    OK, Scotty...heres the changes from 176AE105 to 176AE106
    What are your thoughts.
    All other varables are the same except for the images show. Note injector size, it does seem to be a big change.
  • wildchild
    wildchild
    If we had a reliable tuner localy I would go that way (local dealer doesn't know his stuff) so I have no option but to do it myself..."3 hours to next dealer"
    Bike runs fine only turns over a few times before it fires and when it fires it sounds like there is a bom in the cylinder...not all the time though.
    Could there be to much cranking fuel?
  • wildchild
    wildchild
    Sound's good...was it a dyno tune or a tweak...I'll give it a go...send me a link.
    Thanks your a champ.
  • wildchild
    wildchild
    Scotty, thanks for the file..I'll go over the tables before I make the call to use it.
    Much appreciated.
  • wildchild
    wildchild
    Scotty, Any chance of a copy of the 09 SEST Software.
  • Liquid Force
    Liquid Force
    Hi Scotty,
     Is there any chance of reloading that 96ci map, as the link is dead, I have an 07 FXSTB with SE filter and slip-on's and a SEST and I am looking for a good map to start with, and go from there.
    James
