Online: FONTANA302
OK Heads again!
  • GOZZ
    GOZZ
    Can anyone suggest who in VIC, SA, or NSW has mega experience, and huge PROVEN skill in building, scraping and filing heads?
    I am looking for a workshop that can take care of my Twin Cam heads and take them out to a place that will give me large HP increase.
    The main options seem to be to buy over the heads that screamin eagle offer, or to send heads to states. ( US)
    Does anyone have any other options?
    I am also thinking it's best to change over my SERT for a Power Commander so that I can get a decent dyno tune without having to go to the STEALERS!
    Anyone else done this?
    Ssya in Tassie some day.
    GOZZ
  • nobody
    nobody
    Gozz
    Heads alone are not going to give you what you desire.Would need to know what the intended use of the bike will be and what the rest of the engine build will consist of.One thing though,you are better off doing your heads than buying Chirping Budgie Heads.
    nobody
  • Surly
    Surly
    Gozz,
    You could ask the US suppliers if they will supply the cores as well.
    Surly
  • GOZZ
    GOZZ
    AWESOME RESPONSE GUYS.
    THANKYOU.
    SOUNDS LIKE HALLAM BOYS THE GO.
    I HAVE A 103, PIPES, HIGH AIRFLOW ETC, JUST THINK HEAD WORKS, AND LARGER THROTTLE BODIES, WITH THE RIGHT CAMS SHOULD DO THE TRICK.
    PLUS A POWER COMMANDER.
    THANKS AGAIN.
    GOZZ.
