Online: Hilly, FONTANA302
Replacing Clutch Cable 0n 08 Fatboy
  • wildchild
    wildchild
    I am about to drop the oil in the tranny..time to replace my std clutch cable with diamond back.
    I have std headers with slipons..do I have to take the headers off or can I do the change leaving them on...although there is a support bracket on the lower pipe I will need to remove.
    WC
  • wildchild
    wildchild
    Thanks Scotty...........
