Lowering Kit
  • WILO
    WILO
    I pick up my new FXSTC next week and have allredy spent 5 grand predelivery.I now want to lower it but at $120 hr labour i was thinking it may be a job i could do myself. Just wondering whats involved and how much for parts.        Thanks Willo
  • wildchild
    wildchild
    Man these dealers know how to charge..120 bucks an hour what a joke...if your changing the shockies you will need a jack to lift the bike off the ground and a manual as well..not hard at all. You will need to check your belt tension after lowering is done.
    A bike lift is the one for the job.I use mine all the time.
    WC
  • WILO
    WILO
    Fare call Beeza your probably right mate but i just resent paying $120hr for labour.I would love to earn just half that . The $5000 was mainly parts.
  • ductor
    ductor
    Don't get the dealer to do it. there plenty of Harley workshops around I'm sure their pricing will be more competetive.
        Ductor
  • GREG
    GREG
    Mate, if ya just getting the lowering bolts put in get the dealer or an indipendent mechaic to do it. It takes 30-40 minutes and its hassel free (forthem). Unless you already have the tools and manual and hassel removal pill handy.
    But I hate working with anything under a heap of spring tension.
  • Robbo
    Robbo
    Hey WILo, if your in Perth, I've got a set of shocks off my 07FXSTC with the lowering bolts already installed for sale. I have the jack and a spare couple of hours to install them!  Why am I getting rid of the shocks, I installed a set of progressive 422 and do not need the originals.
  • WILO
    WILO
    Thanks for the help.I ended up speaking  to the dealer and there happy to chuck it in free of charge.
  • SuperGlide
    SuperGlide
    haha Beeza' - good call
    Good luck when pillioning.
  • Peter
    Peter
    Hey Superglide why did you say good luck when pillioning ?? I am thinking about putting the lowering bolts on my softy (I only want to lower it an inch or so ) but I pillion 85% of the time, should I be concerned ??
  • GREG
    GREG
    Just Do It Peter. I have carried some heavy people and only rarely bottom out.
  • Peter
    Peter
    Rightothen
