Online: tussuck, Hilly, speedzter
Any Tuners in Sydney that know 08 RKings
  • Fr3d
    Fr3d
    I have an 08 Road King: 103, 211, SERT, SE slip on, stock headers.  85hp and 86ftlbs of torque, I expected more.  Maybe when I get a better exhaust.
    No one seems to be able to fix the problem with the throttle response off idle.  Suckered by HD.  If I had known, I would have stayed away from the FBWire.
    I have looked at the Xied, not sure - T/max does not have a ECM for these bikes yet.  My only choice seems to be to find someone who really knows how to work a fix with the SERT.
    I would really appreciate anyone being able to give me a direction to head in or give me the name of someone in Sydney that can fix this problem?
    Fr3d
  • sophtayl
    sophtayl
    Hi Fred,
    what seems to be the problem?
    Mick
  • Fr3d
    Fr3d
    Mick,
    Especially when the bike gets hot and in traffic the throttle does not respond the way it should. Load the motor by letting out the clutch and the motor near stalls or does stall. The bike idles ok but twist the grip for take off and it hesitates and does not have the immediate power drive through the clutch. Hope that makes sense.
    Fr3d
  • sophtayl
    sophtayl
    When you had it dynoed, did they tune it or just load a canned map and give you a dyno reading?
    Mick
  • Fr3d
    Fr3d
    The first dyno tune got rid of the heat but the bike lacked punch. The second dyno brought the heat back but the bike out of closed loop goes a lot better. The first was a modified canned map, the second more than likly a modified canned map. Both maps had the throttle response issue, the second more noticable because the bike gets hotter quicker but this also could be because the weather is warming up in Sydney now.
    Thanks
    Fr3d
  • sophtayl
    sophtayl
    Hi Fred,
    Im not sure if the throttle issue is map related or FBW related.
    we can take a look at it for you.
    One option is to go with the FuelShot which is designed to adjust fuel load based on load the bike sees along with having the bike run significantly cooler, but we should be able to sort out the tuning with the SERT ( I take it you have your dongle for the SERT).
    We are based in Albion Park Rail, just south of Wollongong if you are interested.
    Kind regards
    Mick
  • Fr3d
    Fr3d
    Yes I am interested Mick,
    What is your address and phone number. I will ring before I ride down.
    Regards
    Fr3d
  • Hoodaman
    Hoodaman
    Mate i seem to have the same prob with the stalling.....same bike as well.......made me look like a dick on the bathurst run....
  • sophtayl
    sophtayl
    Hi Scotty,
    maybe you can assist Fred with some guidance as to the cause of his problem. If it is the TBW, then he won't need to waste his time chasing ghosts, and can focus on the right area.
    Mick
  • Fr3d
    Fr3d
    Thanks Mick, Hi Scotty,
    I have a SERT. If I had known maybe I would have got the SEST or TTS
    My understanding is at idle the bike runs in closed loop. This means lean AFR (14. something) until the rpm are above a certain level when it can drop out of closed loop and go into open loop. When the bike gets hot the problem seems to be worse, maybe gets leaner leaner, twist the grip and its not rich enough to bogie. Instead you have to baby the clutch to get off the mark. Narrow band O2 sensors dont let the bike to fuel rich enough in closed loop mode.
    That's why I asked about those Xied type products at the start of the thread to see if they really can trick the ECM into compensating for what is seeminly real lean readings from the O2 sensors.
    This is something I have to fix. One day when I need to burn rubber, this wont cut it.
    R
    Fr3d
  • Fr3d
    Fr3d
    Hey RT
    Life was simpler with my FXDWG as well but times change. I dont want to put shit on HD because after all my RK rocks. It was tempting just to jump on and ride down but lifes busy till way after Xmas.
  • Fr3d
    Fr3d
    Hi Scotty,
    I will have to really check out this throttle lag a bit more. I did not get the feeling the lag was the problem. I have been thinking that as soon as the motor is loaded by engaging the clutch, the motor does not have power and stalls or wants to stall. If I sit at the lights and twist the grip in neutral or with clutch in, there is pretty good response. Not as good as my old wide glide with cable though. I would have also thought that throttle lag would be there irrespective of the temperature. Just a thought and if you are on the case a little more info.
    Thanks
    Fr3d
  • Fr3d
    Fr3d
    Thanks Scotty
  • mooky160
    mooky160
    Fr3d,
        Check out the latest heavy Duty mag there are a couple of articles on problems with the FBwire and how to resolve them.  may help.
