Online: speedzter
thunder max questions
  • jim76
    jim76
    1, IAC home position= how much of a differance should i notice when droping by 5. i have dropped it by 10 now and still not much of a differance. should it be a big drop or it is only a small drop when adjusting it?
    2,Reading learned off sets= If i do this then write back to module it should start learning from what it has all ready learnt all ready n not from the base map? bike seemed to run a hell of a lot better after doing this on a quick ride i went for
    3, Not a question may help someone out, i was having trouble with the bike back firing thorgth the air filter when slowing down giving it a blip on the gas when changing down gears i sent zippers an email they said to adjust the accel fuel down by 1 untill problem was no longer there. i adjusted it down this arvo n seems to be gone will take bike on a longer run just to c that it has fixed it
  • PigironBob
    PigironBob
    1 Not sure why you would need to do this if you have the auto tune module.
    2 Yes this is correct, I have been doing this after every 6 to 8 rides over 70 km in length. Eventually you will cease noticing changes as the learning will be less and less, this is a good thing.
  • PKSHED
    PKSHED
    If you Blokes would have wacked in one of Joe's Fuelshots in the first place, you don't have to touch fuckall after every coupla rides.
  • jim76
    jim76
    Thanks for the info, the IAC adjustment is for when i start bike up hot it idles high then comes back to a good idle. i was starting to think i may have been dreaming on how well the bike went after writing the maps back to module was impressed with how it ran.
