Online: Retroman, Wanderer57
07 Airfilter back plate & wiring
  • Jono
    Jono
    18 years ago
    Hello,
    Im re-posting this to Australian Forum as I put this to the HD Forum before I even knew this site was up.  Hopefully there might be a better answer from Oz readers?
    it goes:
    I have installed a K&N stage 1 high flow filter to my Road King Classic 07.  I removed the original back plate and disconnected the wiring to what looks to be a choke flap. When I installed the K&N back plate there was no harness for the original wiring to attach to, now I have a constant engine warning light on my panel. Im assuming its the open wiring thats not reconnected.
    Can anyone advise whats ment to happen with the un-used wiring and the engine warning light ?
    Thanks.
    Spot.
    1st posted to HD USA http://www.hdforums.com/m_2214009/mpage_1/key_/tm.htm#2214009
    This is the site for the part from a UK supplier http://www.harley-mania.co.uk/product_info.php?products_id=1314
  • nobody
    nobody
    18 years ago
    The product you require is an intake solenoid eliminator.Try Here www.bigjoechoppers.com.au/eliminators.html
     Besides that they advertise on the site and are forum members.Hope the link gives you the info you need.
    nobody
  • Today
    Today
    18 years ago
    You guys are talking about the stuff I pay for..........  I have a lot to learn!!!!!
  • sophtayl
    sophtayl
    18 years ago
    Hi Jono,
    as Nobody indicated:
    the light (or I should say the code generating the light) is directly related to the plug that is left open. The code should say P0661. ( refer to the other section of the forum if unsure how to pull the codes http://www.hdforums.com.au/Default.aspx?tabid=71&view=topics&forumid=12 )
    What is happening is that the butterfly is normally closed until you hit 70kph and above with at least 50% throttle.
    The P0661 is indicating an open circuit. In this case it is because the solenoid is not there.
    Thet intake solenoid eliminator will fix the problem. Yuo need to make sure you clear the code from the dash when you do or you will still end up with a historic code for the next 50 ignition cycles.
    Hope that helps.
    Kind regards
    Mick
  • Today
    Today
    18 years ago
    Sophtayl,  I'm glad you are in this forum.......one day I know I will need you!!!!!!!  Gees you know your S**t!!!!
  • sophtayl
    sophtayl
    18 years ago
    My Pleasure Today.
    Im happy to help where I can.
    Kind regards
    Mick
  • nobody
    nobody
    18 years ago
    Hey Mick what is the best way to contact you and order the eliminators? Just ring the mobile number on the website?
    nobody
  • sophtayl
    sophtayl
    18 years ago
    Hi Nobody,
    If you want to know more or have some questions about the eliminators feel free to call the number or drop me an email.
    If it is to purchase a set, the website is set up to handle that directly for sets of intake and exhaust plugs via paypal. If someone wants to purchase an individual plug ( eg for an 06 softail you only require the intake plug) then dropping me an email is fine too.
    Alternatively, given that most people here are in Oz, Bank transfers are quite feasible so people can email me for account details etc. mick@bigjoechoppers.com.au
    Let me know if you need anymore info.
    Mick
  • nobody
    nobody
    18 years ago
    Thanks Mick
    I will do it through the website now
    nobody
