Online: Bullshark001
headlights on fatbob
  • clarkey
    clarkey
    Does anyboby know if you can buy the reflecters and bulbs to make both lights work on high and low beam or go through america to get a complete headlight from usa or would it be illegal over here as you would think the beams would throw to the right.  would love to know thanks
    while im here has anyone had trouble with the back foot peg bolts as the heads broke off mine all stainless now
  • PigironBob
    PigironBob
    Yes you are right the US headlight will be biased the wrong way.
    I replaced the head lights on my FXDF see the following thread;.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=4&postid=26686&view=topic
    Some have done what Roadtrain has posted above.
    No trouble with the rear foot pegs, I took them off.
    Bob
  • Bli Bli Bandit
    Bli Bli Bandit
    1st I did the "Roadtrain mod" and it worked great, then the headlight copped a rock through it so I bought the american headlight, the bias may be wrong but the spread of light seems just right to me, it is the best headlight I have ever had on a harley and well worth the money spent. I think all the part numbers and costs are listed in the Dyna section.
