Online: Stuart
More cam questions
  • johno1
    johno1
    I am thinking of changing the cams in my 96B as well to get a bit more out of the engine.
    Frasers have suggested SE211's, but talking to a few others, they are suggesting SE204's. (I am going to go with SE due to not wanting to void any warranty issues)
    Does anyone know if there are any sites showing dyno curves for the 2 different cams with stock engine. (it does have a SERT, S&S slipons and air cleaner mods) or any sites where this has been discussed before.
    Whats the general concensus from those who have fitted either of these cams.
    I am looking for lower to mid range torque and a bit more HP and at this stage am not thinking of any other engine mods. (I have read that the 211's go better with a 103 kit, which is why I'm wondering why Frasers suggested it.)
    So brains trust.................any comments would be helpfull.
    Johno
  • johno1
    johno1
    thanks Scotty, I will check that out with them tomorrow.
  • PigironBob
    PigironBob
    Hey Johno, Bobtail has 204's in his, he reckons they are great. Dunno what sort of ECM he has.
  • johno1
    johno1
    Yeh I know PIB and I will probably go that way. What I am trying to find out is why Frasers have suggested 211's when the SE performance blurb says that 211's should be used on higher compression motors or 103 kits.
    I reckon Scottys right and they don't have a map for 204's with a SERT.
    I will check it out tomorrow and post their response. (I think BT runs a thundermax)
    Frasers told me the same thing Alan, but I'm not necessarily after HP, just some more torque low to mid and from what I can find the 204's should be better.........hence my question to our esteemed forum community.
  • andij
    andij
    jonno u need high comp for 211s to get the most of em crashers got em ,me and bt got 204s they are fine as bolt in cams they give 96 a wakeup call but for big performance the 103 build up as in heavy duty on the dyna with in house se gear sounds good ,but are u gonna ride with extra power without improvin suspension wich u gonna need ,for bang for buck 204s r hard to beat souwest harley can give you info inc dynos on most cam s they recomended them to me for the price i was gonna spend iam happy i can keep up with billy and most guys i ride with .plus i have pc111 on board
  • johno1
    johno1
    Alan,
    I'm heading down Sat to have a chat about it with the service guys.
    Mine to is the 8K service as well and from all the net surfing today and talking to a few guys I think the 204's are the go so I will get them installed at the service.
    (One of the guys at work is a custom Harley bike builder and has all the software in case I need it as well). I will keep you informed.
  • andij
    andij
    beeza you know heaps ,ur humour reminds of the goons ,2 ronnies ,3 binmen , ;;;;;; dont do a dummy spit ,,,, i can recognise anger ,abuse,sexual perverson on your heavy handed writin ,
  • johno1
    johno1
    Picked the bike up from Frasers this arvo after having the 204's fitted. Only a few km's from there to home, but in that distance there is a noticeable difference with the bike........quite pleased.
    HP is up at 82 and torque 92 with a smooth curve from 2200 to 5200, hopefully I will get out on the weekend and try it out.
    Cant give a cost because Frasers mucked me around a bit and when they finally did the job they did the right thing by me and reduced the price.........good service in the end.
