Online: tussuck
SE Heavy Breather
  • shfunky
    shfunky
    Hey gurus, anyone out there fitted a SE Heavy Breather air filter, I might be missing something but what happens to the crankcase ventilation, on my SE Stage one there was rubber breather tubes that went from the breather bolts to the throttle inlet whereas on the Heavy breather there are just chrome plugs with o rings.  ???
  • shfunky
    shfunky
    In the light of day have had another look and can see 2 small holes that run down through the backplate into the throttle inlet. Case solved. Thanks.
