How to check Dyna motor mounts????
  • 1elcys
    1elcys
    Anyone got any ideas what to look for when inspecting your motor mounts on a Dyna, do I just look for worn rubber or is there a special technique to checking  them?
  • 1elcys
    1elcys
    LMAO good point.
    they must be ok then.
    The manual is a bit vague they just say to check the rubber I can't even see the fucking rubber.
  • PigironBob
    PigironBob
    The front rubber mount is under the oil filter, the rear one is on the rear center of the transmission case, to see the rear 1 the bike will have to be lifted unless you got a small head. There is also a top mount that bolts onto each head with bracket and a cross arm that mounts to to chassis have to lift the front of the tank to inspect this one.
    1 Check for cracks or tears in the isolator rubber.
    2 Check stabilizer links for wear.
    3 Check that all engine mount bolts are tight.
    4 Check engine mount rivets are not sheared.
    Check the mounts are supporting the weight of the motor.
  • 1elcys
    1elcys
    Yeah I have read that article thanks appreciate the link.
    I will do that before I fit the true track.
    when I am in gear riding at anything above 80k's under that it vibrates a bit especially when idling I have 1-1/2" bars and they vibrate a lot at idle.
    A bit more than a 2001 sporty anyway.
  • TNT
    TNT
    Thanks for that link Mainey some good info there m8 certainly something to think about for the Dyna's
  • 1elcys
    1elcys
    I didn't know Harleys had a warranty.
    Thats just a myth isn't it.
