Online: Retroman, Wanderer57
07 fifth gear
  • rooshooter
    rooshooter
    18 years ago
        well i have had enough of ridin this bike with a tranny that is sounding like a mixmaster [and a crook one at that]
    the glide has just clicked over 14000 clicks . had service manager take a ride of it today and he agrees it aint right, too noisy in fifth gear
    also has to fix oil seep around clutch cable area and rear bumper brackets both broken
    not here to start "harley bashing" i really love the bike, but a little disappointed in havin these problems
    will be hanging out to hear what the mechanics find
  • Today
    Today
    18 years ago
    Bummer mate......hope all goes well.  Looks like a great ride.
  • kingchops
    kingchops
    18 years ago
    Nothing sucks more than having problems like that with your new bike. Response from dealer service makes all the difference, hopefully they're cool to deal with and look after you.
  • BACAMICK
    BACAMICK
    18 years ago
    mine is quite , maybe im just lucky, be good to see if they fix it
  • kensim
    kensim
    18 years ago
    i must be lucky ,touch wood, no oil leaks and no real noise from fifth gear maybe bikes to loud.
  • Rocket
    Rocket
    18 years ago
    So Rooshooter, what's the go with your noisy trannie ?
    Will they fix it under warranty ? Do they know what it is ?
    I complained on my first service (07 RK custom) but they just said that they do that and that was it.
    But mine makes noise in the top three gears, fourth isn't too bad, fifth is terrible between 70 and 80 odd ks, sixth isn't too bad either but I figure wind noise drowns most of it out.
    I will complain again on my next service, and the next, and the next etc etc
    Does anyone know what models are affected ?
    My mate has an 07 street bob and hasn't complained, but I thought the motor and trannie would be the same as mine.
  • nobody
    nobody
    18 years ago
    My Roadking whines like a banshee in 5th but is ok in other gears,not going anywhere near a dealer to get services done so won't be complaining to anyone.
    nobody
  • rooshooter
    rooshooter
    18 years ago
     hey rocket
             just typed a reply in the intro section
    picking my bike up at the end of the week so will know a bit more then
    not really happy with the srev. managers reply today but at least the shop pulled it apart to have alook
    they reckon nothins wrong but are waitin for a couple of bearings to come .......... fom what i  can gather they have had a good look at all the gears + bearings
      wonder why they are replacing two bearings if they aint broke ?
  • Rocket
    Rocket
    18 years ago
    Just to keep you happy I reckon mate.
    Yeah I saw your reply after I posted above.
    They tell me it does no harm to the box but how can something that sounds so bad be okay ?
    Imagine what happens when I go to sell it and the guy test rides it and and says "geez the gearbox is noisy" and I say "oh they all do that"
    I wonder if he'll believe me.
    Don't get me wrong, i love the bike. But my old softail never made a peep from the gearbox, newer is supposed to be better....apparently.
  • Bobtail
    Bobtail
    18 years ago
    Hey rooshooter if you go to the US HD forums site there is a thread in the bagger section that has hundreds of stories about the 5th gear noise problem. There seems to be a fix that a lot are happy with, relates to the replacement of  the final drive pulley with a rubber damped one (IDS) anyway might be worth a look.
    Good luck
    Bob
  • GMR-PERFORMANCE
    GMR-PERFORMANCE
    18 years ago
    HD does sell the kit for the rear called a isolater, that will reduce the noise you are hearing. It bolts into the rear pulley and reduces the noise
  • nobody
    nobody
    18 years ago
    The isolator only removes the rattling type noise not the Whine from 5th.
    nobody
  • GMR-PERFORMANCE
    GMR-PERFORMANCE
    18 years ago
    HMMM if you say so , I have done a few and it has removed most of the gear noise. We have had good luck with it sorry that it has not worked for you. Did you try a syn fluide in the trans like bel ray??
